Home > General (L494) > EGR valve tick?!
Sam_RRS
England 2013 Range Rover Sport SDV6 HSE Fuji White
EGR valve tick?!
Hi all, Im new to the site & been reading few posts but time to register & join in!
I have owned a RRS 65 plate HSE Dynamic for a couple of months now. Absolutely love driving the car but as expected I've had a few problems. Once the engine is upto temperature it makes a tick sound. Its the actuator on the EGR valve sort of ticking/bouncing rapidly. I thought the diaphram had gone so had new EGR fitted drivers side so both been done but still got the noise. Didn't show up a fault on dash & seems to drive fine, just noise is so annoying.
Mainly noticeable at idle & on overun but only once the engine is fully warmed up. Any ideas??
Post #637557 Thu Nov 23 2023 11:01pm
thejack
Italy 2012 Range Rover Sport SDV6 HSE Orkney Grey
Hi, did you sort out what the cause was? Mine SDV6 is doing exactly the same sound and it's driving me crazy!
Post #644436 Fri Sep 27 2024 11:51am
Sam_RRS
It turned out to be a vacuum leak near one of the engine mounts. Local indie wanted to replace engine mount which wasn't covered under warranty for £xxxx so I went to local main dealer service centre for second opinion, thought it was worth an hours labour. Went to pick car up & they said they've resealed the leak all good now. Some main dealers are worth it, Thank you to Team Valley Land Rover.
Post #644472 Sun Sep 29 2024 12:45pm
