Home > Faults & Fixes > Brakes warning light
Michael997
My 2013 L320 RRS just had new brake discs and pads fitted all around including new wear sensors but the brake pad warning light is still on, is this a known issue and is there a fix? and suggestions welcome Michael
2013 RRS diesel Autobiography Dynamic
Post #637471 Tue Nov 21 2023 8:25am
Initially I would check they have actually refitted/connected the the wear sensors correctly and not damaged either.
Post #637472 Tue Nov 21 2023 9:06am
Michael997
Thanks, the specialist still has the car and reported the issue to me so hopefully he will check that but I will mention it to him, he is someone I trust but he isn’t sure what is wrong. Michael
Post #637477 Tue Nov 21 2023 10:20am
MHSPORT08
I've just had this issue on the mega mileage TDV8 i've taken on.
I found the rear pad sensor had been broken from new by the last person who put pads in and its worth testing the sensors for continuity off the car. Also inspect the wires on the loom where the connectors plug in as they can get damaged if tugged on too hard.
Once I fitted the new sensor the light on the dash went out, no clearing of faults needed
Hope they can sort it
Post #637517 Wed Nov 22 2023 10:25am
Stuart
Michael997 wrote:
the specialist
I'd suggest to him that as a specialist, you use him because he can find out what's wrong. Get a 2005-2009 RRS (FAH500210) sat nav/dash mat here - the one that wasn't there when you bought the car.
Spiffing wheel centre caps available
Post #637521 Wed Nov 22 2023 1:56pm
