Home > General > Warped front discs?
Salisburylander
2011 Range Rover Sport 3.0 TDV6 HSE Bali Blue
Warped front discs?
One of my friends has just bought a RRS, he let me have a test drive; all went well until I had to brake. The steering wheel really juddered badly and you could feel it through the whole car.
I assume that it is warped front brake discs, anyone agree with me?
Post #637202 Sat Nov 11 2023 1:53pm
Dave B
Possible, and more than likely, however dodgy wheel bearings will give the same effect, as can knackered suspension joints, so whilst you might be right, you could also be wrong.
Dave 2010 3.6 TDV8 HSE (Gone)
Post #637203 Sat Nov 11 2023 2:07pm
NoExpert
Could be the rear rotors as well. 2011 RRS HSE Luxury 3.0 TDV6 Fuji White on Ebony/Ivory
Post #637204 Sat Nov 11 2023 3:18pm
Salisburylander
All the discs looked like they had seen better days. The steering did feel a little remote and pedestrian too.
I’ll get him to check other suspension components too.
Post #637205 Sat Nov 11 2023 3:22pm
JDPRRSUK
United Kingdom 2012 Range Rover Sport 3.0 TDV6 HSE Lux Santorini Black
Could just be poor transfer of material on to the rotors - ie not bedded in properly and now have ‘lumps’ of pad material on them. Might be worth cleaning them before jumping to replacement unless they are knack*rd
Post #637206 Sat Nov 11 2023 3:53pm
An incompletely tightened wheel can give some nasty vibrations when loaded even if it's ok at other times. 2012 SDV6 - it's missing a couple of cylinders
Post #637212 Sun Nov 12 2023 10:02am
Puslinch
United Kingdom 2012 Range Rover Sport 3.0 TDV6 HSE Firenze Red
My MY2012 eats front brakes. Every 2 years they need to be replaced and I still to this day have them done at the dealer under warranty.
The car is too heady for the size of the front rotors I’ve heard, could be an urban legend.
I doubt its bearings, etc. mine has always been brakes. This is driving 6,000 miles or 10,000 miles year.
None of my other cars have this issue, Porsche, Mini, or Jeep. 2018 Telsa MS
2012 Range Rover Sport HSE+
1990 Porsche 944
1985 LR 90 Soft top V8
Post #637285 Tue Nov 14 2023 6:40pm
Meiang
The runout could be any number of problems. You will need to fix them first to get an idea of where to look.
I just replaced my discs and pads (front and rear) on my 2010 TDV8. This is the first time they have been replaced since the car was new (apart from the rear pads which were replaced a few years ago). 13 years is not bad for a set of brakes. The only reason I replaced them was the front pads started to "machine" the disks - no pad material left. Lots of screeching.
Post #637321 Wed Nov 15 2023 10:22pm
13 years for a set of pads and disks is OK, but as you never say what milage you have done, if it's only 25k it ain't good is it.
Post #637329 Wed Nov 15 2023 11:26pm
Meiang
The car has just over 75,000Km on the clock and spends about 1-1.5 h per day being driven (stop start driving).
Post #637331 Wed Nov 15 2023 11:50pm
