![]() | Home > Technical > ECU and BCU |
Andy K Member Since: 18 Sep 2015 Location: GL Posts: 5036 ![]() ![]() ![]() |
That’s what you need I believe. There are matching kits of these items on eBay.
Disco_Mikey Member Since: 08 Apr 2012 Location: Dundee, Scotland Posts: 4446 ![]() ![]() ![]() |
You need a way of forcing RRS Firmware into the D3 modules, if you do it that way |
Simon_CSK Member Since: 21 Dec 2020 Location: East Ayrshire Posts: 70 ![]() ![]() ![]() |
What do you mean? At this stage all I want to do is see if the car will run. Airbags are deployed and have various other bits to repair but not worth doing if it doesn't run. Current cars
Silly things, like the tailgate won't open, and the SRS settings are different, and the CCF will be wrong
I still have the receiver ring to change so am interested in seeing what will happen. Current cars
Goffy Member Since: 31 Oct 2018 Location: Milton Keynes Posts: 82 ![]() ![]() ![]() |
Could the problem actually be that he KVM module is of the earliest type, to which you cannot programme a new key? Might the answer therefore be to get the later KVM module and programme the key to that?
Col Member Since: 02 Sep 2012 Location: Hawkes Bay NZ Posts: 5062 ![]() ![]() ![]() |
Not sure that applies as the 2006 model was not keyless.
