Home > Technical > ECU and BCU
Simon_CSK
ECU and BCU
I have just bought an 2.7 HSE 2006 RR Sport with no keys. Have done this in the past and have done various things to get the car started. This time I got a lock smith to cut me a key and programme it to the car but came up with an F fault on the dash. Managed to resolve this but still the remote would not work.
I have a 2007 2.7 HSE Discovery has anybody tried changing the body control unit, engine ecu and dash clocks over to get a car running? In theory there shouldn't be an issue as both cars are exactly the same underneath with the exception of the ACE. Current cars
Range Rover Sport HSE TDV8
Range Rover TDV8 Vogue
Range Rover P38 Vogue
Range Rover CSK
Discovery 3 HSE
Post #636699 Thu Oct 19 2023 3:56pm
That’s what you need I believe. There are matching kits of these items on eBay.
Make sure it’s suited to your engine
Post #636701 Thu Oct 19 2023 4:49pm
Disco_Mikey
You need a way of forcing RRS Firmware into the D3 modules, if you do it that way
Post #636702 Thu Oct 19 2023 4:53pm
Simon_CSK
What do you mean? At this stage all I want to do is see if the car will run. Airbags are deployed and have various other bits to repair but not worth doing if it doesn't run. Current cars
Range Rover CSK
Discovery 3 HSE
Post #636703 Thu Oct 19 2023 4:55pm
Disco_Mikey
Silly things, like the tailgate won't open, and the SRS settings are different, and the CCF will be wrong
You need a way to correct these issues, but no idea if it will start and run without correcting them
Post #636708 Thu Oct 19 2023 8:24pm
Simon_CSK
I still have the receiver ring to change so am interested in seeing what will happen. Current cars
Range Rover CSK
Discovery 3 HSE
Post #636709 Thu Oct 19 2023 8:26pm
Goffy
United Kingdom 2010 Range Rover Sport 3.0 TDV6 HSE Alaska White
Could the problem actually be that he KVM module is of the earliest type, to which you cannot programme a new key? Might the answer therefore be to get the later KVM module and programme the key to that?
Mind you, there would be the cost of the KVM.
Post #636715 Fri Oct 20 2023 10:16am
Not sure that applies as the 2006 model was not keyless.
Post #636716 Fri Oct 20 2023 10:25am
