Home > General > Fuel filler not lockable?
Pistnbroke
United Kingdom 2009 Range Rover Sport TDV6 HSE Galway Green
Noticed my fuel filler flap does not lock 2009 L320....My friend has a 2010 and his does lock.
Is it an option to retrofit a lock or was it never on the Mk 1 ?
PS found a locking cap on ebay for £8.95 but would prefer it to be electric. Always listen to old people or when they die you will live on in ignorance.
The avatar is a picture of the man with a big cock.
Learned to 4x4 on 100 mile beach and Frazer Island QLD
Dont spend money on old cars you will never get it back
Post #636550 Fri Oct 13 2023 7:07am
It’s broken !!
The plastic end can break off or motor failed inside the car
Post #636553 Fri Oct 13 2023 7:58am
Pistnbroke
OK will get my hand in through the hatch inside and see if it has a motor.
thanks Always listen to old people or when they die you will live on in ignorance.
Post #636554 Fri Oct 13 2023 8:03am
Open flap.
Locate small round hole in the side.
Press the lock button on key while looking at the hole and see if something moves out flush
Post #636556 Fri Oct 13 2023 9:34am
Pistnbroke
Yes can find a motor and cable to the flap. It looks like the end of the cable has been broken off ?? as moving the motor by hand does not cause anything to come out the hole to lock with the flap.
will investigate furthur. Always listen to old people or when they die you will live on in ignorance.
Post #636558 Fri Oct 13 2023 9:43am
I once did a no cost fix.
Pulled the cable out the flap
Removed the shoulder to allow the remaining bit to come out enough.
Then cut the right amount off the outer cable. (The amount you want it to pretrud)
Post #636561 Fri Oct 13 2023 10:27am
Pistnbroke
Yes someone has got out and locked the car ..noticed the flap open and bashed it shut breaking off the plastic bolt.
Solution in my world is take a 5mm bolt ..turn it in the lathe to correct diameter. Small hole in end and braze it onto the stainless centre or the cable.
If you know how far it sticks out into the filler hole that would help me get the length first time. Always listen to old people or when they die you will live on in ignorance.
Post #636564 Fri Oct 13 2023 12:39pm
Mine sticks out 9mm, but it’s non standard.
Length isn’t critical
It’s a bmw design
Post #636567 Fri Oct 13 2023 1:55pm
Pistnbroke
Silver soldered a 3.2mm drill to the end of the stainless wire from the actuator ..careful measurement required ..all working great . Thanks for help Always listen to old people or when they die you will live on in ignorance.
Post #636696 Thu Oct 19 2023 8:40am
