Home > General > Fuel filler not lockable? |
Andy K Member Since: 18 Sep 2015 Location: GL Posts: 5006 |
It’s broken !!
Fri Oct 13 2023 7:58am |
Pistnbroke Member Since: 22 Sep 2020 Location: rugby Posts: 419 |
OK will get my hand in through the hatch inside and see if it has a motor.
Fri Oct 13 2023 8:03am |
Open flap.
Fri Oct 13 2023 9:34am |
Yes can find a motor and cable to the flap. It looks like the end of the cable has been broken off ?? as moving the motor by hand does not cause anything to come out the hole to lock with the flap.
Fri Oct 13 2023 9:43am |
I once did a no cost fix.
Fri Oct 13 2023 10:27am |
Yes someone has got out and locked the car ..noticed the flap open and bashed it shut breaking off the plastic bolt.
Fri Oct 13 2023 12:39pm |
Mine sticks out 9mm, but it’s non standard.
Fri Oct 13 2023 1:55pm |
Silver soldered a 3.2mm drill to the end of the stainless wire from the actuator ..careful measurement required ..all working great . Thanks for help Always listen to old people or when they die you will live on in ignorance.
Thu Oct 19 2023 8:40am |
