Home > Faults & Fixes > Blanking EGR valves - what do I need to know? |
NoExpert Member Since: 28 Jan 2022 Location: Poznań, Poland Posts: 493 |
It’s going to mess things up. The EGR’s work with the DPF, so blanking one requires removing the other. Then you need both tuned out in the ECU. 2011 RRS HSE Luxury 3.0 TDV6 Fuji White on Ebony/Ivory
Thu Oct 05 2023 12:18pm |
riverblanche Member Since: 11 Jun 2011 Location: Retford'ish Posts: 1134 |
Hi,
Thu Oct 05 2023 8:00pm |
Pistnbroke Member Since: 22 Sep 2020 Location: rugby Posts: 419 |
I did see a post where the guy removed the butterfly flap but left the electronics/ shaft in place to fool the computers and then blanked off the ERGs with stainless plates.
Fri Oct 06 2023 7:17am |
Stevepd Member Since: 22 May 2017 Location: Wiltshire Posts: 1251 |
The indie that blanked mine did just that. Inserted the blanks and took out the butterfly leaving the arm. 2006 2.7 TDV6 HSE in Cairns Blue. |
Fri Oct 06 2023 5:54pm |
The 3.0 TDV6 is not the 2.7 TDV6. Very different EGRs where everything is monitored. 2011 RRS HSE Luxury 3.0 TDV6 Fuji White on Ebony/Ivory
Fri Oct 06 2023 8:38pm |
RRSTDV8 Member Since: 12 Aug 2011 Location: Northamptonshire Posts: 9003 |
Just put a new EGR in. 2012 SDV6 - it's missing a couple of cylinders
Fri Oct 06 2023 8:46pm |
Thats why I bought a 2009 2.7...... Always listen to old people or when they die you will live on in ignorance.
Sat Oct 07 2023 6:13am |
garrycol Member Since: 30 Nov 2010 Location: Canberra Posts: 1068 |
"Thats why I bought a 2009 2.7......" yes and if you blank as you proposed above you will still have your check engine light showing. 07MY RRS TDV6
Sat Oct 07 2023 8:25am |
