![]() | Home > Faults & Fixes > Blanking EGR valves - what do I need to know? |
It’s going to mess things up. The EGR’s work with the DPF, so blanking one requires removing the other. Then you need both tuned out in the ECU. 2011 RRS HSE Luxury 3.0 TDV6 Fuji White on Ebony/Ivory
Pistnbroke Member Since: 22 Sep 2020 Location: rugby Posts: 438 ![]() ![]() ![]() |
I did see a post where the guy removed the butterfly flap but left the electronics/ shaft in place to fool the computers and then blanked off the ERGs with stainless plates.
The indie that blanked mine did just that. Inserted the blanks and took out the butterfly leaving the arm. 2006 2.7 TDV6 HSE in Cairns Blue. |
The 3.0 TDV6 is not the 2.7 TDV6. Very different EGRs where everything is monitored. 2011 RRS HSE Luxury 3.0 TDV6 Fuji White on Ebony/Ivory
RRSTDV8 Member Since: 13 Aug 2011 Location: Northamptonshire Posts: 9050 ![]() ![]() ![]() |
Just put a new EGR in. 2012 SDV6 - it's missing a couple of cylinders
Thats why I bought a 2009 2.7...... Always listen to old people or when they die you will live on in ignorance.
"Thats why I bought a 2009 2.7......" yes and if you blank as you proposed above you will still have your check engine light showing. 07MY RRS TDV6
