Home > Technical > Those corner cast weights
Pistnbroke
United Kingdom 2009 Range Rover Sport TDV6 HSE Galway Green
Been looking for a clonk on a bumpy road and it seems the weights can move and bonk somehow.
If suspension is an up down system why do these weights rotate/move front rear ? And what is the explanation of there function?
Anybody taken them off? Always listen to old people or when they die you will live on in ignorance.
The avatar is a picture of the man with a big cock.
Learned to 4x4 on 100 mile beach and Frazer Island QLD
Dont spend money on old cars you will never get it back
Post #636341 Wed Oct 04 2023 6:36am
TheWojtek
They are harmonic dampers for the chassis and have nothing to do with the suspension. Yes, they have been removed for extreme offroading albeit rather due to other body modifications. Yes, you will feel vibrations throughout the car at certain speeds when removed. Yes, there is no reason to remove them. Yes, it is one of the most frequently asked questions. Regards etc.,
Wojtek
WAS: 2006 RRS Supercharged
IS: 2010 RRS TDV8 HSE
Post #636344 Wed Oct 04 2023 7:00am
Pistnbroke
At the moment I have jambed some wooden wedges between them and the chassis to shut them up..we will see ... Always listen to old people or when they die you will live on in ignorance.
Post #636345 Wed Oct 04 2023 7:05am
TheWojtek
They are supposed to be freely moving, though Smile Never had any of them travel so far they hit something and make a noise. Is it the case? Regards etc.,
Wojtek
Post #636346 Wed Oct 04 2023 7:13am
Pistnbroke
Just got a bit of a clonk on a big pot hole so stopped them moving for elimination purposes. Always listen to old people or when they die you will live on in ignorance.
Post #636347 Wed Oct 04 2023 7:15am
Meiang
On my TDV8 from the factory the RH exhaust was too close to the damper weight so it would "clonk" every now and then - only about 5mm clearance.
Post #636418 Thu Oct 05 2023 11:43pm
