![]() | Home > Technical > Those corner cast weights |
TheWojtek Member Since: 08 May 2015 Location: Poznań, Poland Posts: 737 ![]() ![]() ![]() |
They are harmonic dampers for the chassis and have nothing to do with the suspension. Yes, they have been removed for extreme offroading albeit rather due to other body modifications. Yes, you will feel vibrations throughout the car at certain speeds when removed. Yes, there is no reason to remove them. Yes, it is one of the most frequently asked questions. Regards etc.,
Pistnbroke Member Since: 22 Sep 2020 Location: rugby Posts: 425 ![]() ![]() ![]() |
At the moment I have jambed some wooden wedges between them and the chassis to shut them up..we will see ... Always listen to old people or when they die you will live on in ignorance.
They are supposed to be freely moving, though |
Just got a bit of a clonk on a big pot hole so stopped them moving for elimination purposes. Always listen to old people or when they die you will live on in ignorance.
Meiang Member Since: 29 Apr 2011 Location: Perth Posts: 403 ![]() ![]() ![]() |
On my TDV8 from the factory the RH exhaust was too close to the damper weight so it would "clonk" every now and then - only about 5mm clearance. |
