Home > In Car Electronics > Problems with a ghost 2
Barnsnape1
When I got my latest vehicle, an insurance condition was to get an immobiliser fitted. I went for the ghost 2. Largely it works well.
When I come to disarm it, I find the pin entry process is unreliable. I am 100% certain of the correct pin Smile and I know to leave at least 10 secs between attempts, but at the moment I find ut works about 1 time in 4. If instead I disarm it using using my mobile phone app it is 100% oercent reliable.
I’m torn between an electrical problem or a timing problem or other?
Just wondered have other members had similar problems? And what was the fix?
Thanks RRS 4.4 SDV8 AB 2018 – Best of all previous vehicles
RRS 3.0 SDV6 HSE 2016 - Lovely vehicle but 2 cylinders missing. Gone
Discovery 4 SDV6 2015 HSE - Gone
RRS TDV8 HSE 2007 – My intro to RRS. Lovely vehicle. Gone
BMW 540 1998. - Highly tuned and ran for ever. Much missed. Gone
Post #636269 Sun Oct 01 2023 2:23pm
Jabba
Would it not be worth contacting the installation engineer ? 2010 RRS 3.6 TDV8 HSE Galway Green
Post #636271 Sun Oct 01 2023 4:43pm
Scrumpy
Could be something as simple as a sticky or faulty button?
Maybe try changing the code to a different combination.
Not sure of your model year but I remember when I had mine installed there were some buttons that they recommended not using. 2016 RRS SVR Estoril Blue
Post #636274 Sun Oct 01 2023 5:38pm
Farmer Chalk
I have had a similar issue with one of my cars previously whereby the car was receiving what it thought was spurious messages in the can network and seemed to shut that component down . This was rectified by disconnecting the car battery for five minutes and then reconnecting.. bizarrely it worked and the component started working perfectly again…it’s worth a try!
Post #636281 Mon Oct 02 2023 8:47am
Barnsnape1
Thanks for the replies.
In the end I found the fault by repeatedly using the relevant buttons for there intended function until I found one that was unreliable. I then used the unreliable button repeatedly and I assume cleaned it. Ghost has been a lot more reliable since RRS 4.4 SDV8 AB 2018 – Best of all previous vehicles
Post #636738 Sun Oct 22 2023 5:38pm
