Home > General > Spare wheel condition
NoExpert
Doing the park brake shoes as well?
I’m doing my rear rotors and park brake shoes plus spring kit for them this week. Pads are good, parking brake shoes are rough and have chewed up my rotors. 2011 RRS HSE Luxury 3.0 TDV6 Fuji White on Ebony/Ivory
Post #636238 Sat Sep 30 2023 7:35am
JDPRRSUK
United Kingdom 2012 Range Rover Sport 3.0 TDV6 HSE Lux Santorini Black
Wheel looks great now…
Post #636243 Sat Sep 30 2023 1:38pm
TTR
United Kingdom 2012 Range Rover Sport 3.0 TDV6 HSE Santorini Black
Eh up all
Well to close this out and in case it’s of use to anyone else.
Got 2 x 180 mm Michelin valve extension and mounts , about £5.00 delivered Very Happy
When I attempted to put them on my valve on my spare air pi88ed out Crying or Very sad
Figured it was simply that the tyre valve thread was not long enough so elected to file of 2mm of the brass knurled connection on the extension - worked a treat Thumbs Up
You definitely need the two extension linked together otherwise reach to the tow mounting point is not sufficient
Gave the extension a brief coat of silicone grease - ran them up and over into the back of the tow mount
Only other adaptations I made was cut off the valve mount return on the metal bracket that has the spring clip on it and fixed it with a nylock
Worked a treat
Sorry no photos as it Censored it down on me and did it on the drive - not 😆
Thanks to Col and NoExpert for the advice
JDPRRSUK - thanks for the comments- I’m chuffed with results at least it’s usable now
I’m dead chuffed can check the spare for pressure with ease - bet I never bl88by need it now Rolling with laughter
NoExpert - doing rear discs n pads but a bit concerned about the epb- reading Bodsys looks like I need a reader to engage the epb in service mode will start a separate thread and all help appreciated
Cheers all hope this post helps someone else Thumbs Up
Post #636246 Sat Sep 30 2023 3:49pm
