Home > General > Gearbox Guard
TTR
United Kingdom 2012 Range Rover Sport 3.0 TDV6 HSE Santorini Black
Gearbox Guard
Eh up all,
I’m trying to figure out if my car is missing a gearbox guard Confused
It’s a 2012 SDV6 , it’s got the small front guard and then the larger full piece rear guard but it certainly looks to me like there’s a guard missing.
Anyone confirm if I’m correct or should it have one and if so a part number or photo or theirs Very Happy
I think I’ve found the part I need - but am I right Thumbs Up
AH32-6B629-AA
As always appreciate anyone’s input as want to secure before winter
Post #635972 Tue Sep 19 2023 8:10pm
Google LR031644 superseded to LR069243 same item, the number you quoted is actually the engineering number.
Post #635974 Tue Sep 19 2023 8:54pm
NoExpert
Be sure to get one from a late 2011 to 2013 since the earlier ones won’t fit correctly. 2011 RRS HSE Luxury 3.0 TDV6 Fuji White on Ebony/Ivory
Post #635978 Wed Sep 20 2023 3:55am
All facelift 320L's now cross reference to the same part number, so theoretically they should all swap/fit.
Post #635979 Wed Sep 20 2023 4:22am
TTR
Eh up
Col - thanks will sort least I know it’s missing and I need one
NoExpert - cheers will get it checked out as definitely want to get right one on
Next laugh will be finding clips and nut sizes that secure it 🤨👍
Cheers all - appreciate the reply
Post #635981 Wed Sep 20 2023 7:08am
Same 6mm setscrews and spring clips as used on the small shield under the radiator. Rolling with laughter
Post #635982 Wed Sep 20 2023 7:28am
TTR
Eh up Col
You’ve really made my day now Big Cry Rolling with laughter
Still under therapy for that little job
Post #635983 Wed Sep 20 2023 7:35am
I thought the bolts were different (smaller) to be honest, but you are probably correct
Also the front 2 and rear 2 are different bolt lengths (2 of them have spring clips)
Post #635986 Wed Sep 20 2023 10:59am
TTR
Eh up Andy K
Thanks for that I can feel a load of pi88ing around again for me on this 🤔
I’ll wear my Bump Cap though 🤣😂🤣 - as said still in therapy after the simple job of removing my small front sump guard
Post #635989 Wed Sep 20 2023 11:19am
As I said the bolts are M6 x 13.5 mm long, the spring clips are LR027995 which are the same as the front two bolts and clips retaining the small shield under the radiator.
Post #635991 Wed Sep 20 2023 11:41am
TTR
Eh up all,
Success ( not another front sump guard trilogy 🤣)
Managed to find the correct guard for £40 delivered - quality was spot on
Fit to perfection, really chuffed as I did not realise how much protection it would offer to the gearbox casing 👍
Local dealer wanted £241.47 plus VA5 🤬
Anyway ordered clips ( thank Col) and had some flanged M6 laying around that I cut down and added larger washers
And went in like a dream
Just put some protection spray round the nuts and all good
Thanks to everyone for all the help, Hope this thread helps someone else
Post #636095 Sat Sep 23 2023 5:04pm
Odd thing about the transmission shield is the S/C doesn't have one or at least mine doesn't, thought dealer had left mine off early day's when noticed it was missing, but there not even listed in the parts list. Confused
Post #636105 Sat Sep 23 2023 9:08pm
