Home > General > Gearbox Guard |
Col Member Since: 02 Sep 2012 Location: Hawkes Bay NZ Posts: 5029 |
Google LR031644 superseded to LR069243 same item, the number you quoted is actually the engineering number.
Tue Sep 19 2023 8:54pm |
NoExpert Member Since: 28 Jan 2022 Location: Poznań, Poland Posts: 493 |
Be sure to get one from a late 2011 to 2013 since the earlier ones won’t fit correctly. 2011 RRS HSE Luxury 3.0 TDV6 Fuji White on Ebony/Ivory
Wed Sep 20 2023 3:55am |
All facelift 320L's now cross reference to the same part number, so theoretically they should all swap/fit.
Wed Sep 20 2023 4:22am |
TTR Member Since: 14 May 2023 Location: West Yorkshire Posts: 165 |
Eh up
Wed Sep 20 2023 7:08am |
Same 6mm setscrews and spring clips as used on the small shield under the radiator.
Wed Sep 20 2023 7:28am |
Eh up Col
Wed Sep 20 2023 7:35am |
Andy K Member Since: 18 Sep 2015 Location: GL Posts: 5004 |
I thought the bolts were different (smaller) to be honest, but you are probably correct
Wed Sep 20 2023 10:59am |
Eh up Andy K
Wed Sep 20 2023 11:19am |
As I said the bolts are M6 x 13.5 mm long, the spring clips are LR027995 which are the same as the front two bolts and clips retaining the small shield under the radiator.
Wed Sep 20 2023 11:41am |
Eh up all,
Sat Sep 23 2023 5:04pm |
Odd thing about the transmission shield is the S/C doesn't have one or at least mine doesn't, thought dealer had left mine off early day's when noticed it was missing, but there not even listed in the parts list.
Sat Sep 23 2023 9:08pm |
