Home > Maintenance & Modifications > HELP! 05 RRS flat battery, and passenger lock won't unlock |
frostmotorsport Member Since: 14 Apr 2014 Location: Wellington Posts: 79 |
let's cut straight to it. I assume a dead battery as neither keyfob will unlock it and checked the battery voltage on one fob and its' 3v so should work ok??
Fri Sep 08 2023 3:26am |
Col Member Since: 02 Sep 2012 Location: Hawkes Bay NZ Posts: 4969 |
The passengers door lock barrel often seizes up due to very rarely being used I believe.
Fri Sep 08 2023 3:55am |
Andy K Member Since: 18 Sep 2015 Location: GL Posts: 4940 |
And if you have the 13? Pin connector, refer to your previous post! |
Fri Sep 08 2023 7:53am |
thanks team. will investigate soon and let you know how I get on.
Sat Sep 09 2023 1:12am |
Why not just connect a charger on a trickle charge for a day or so if you don't need the car straight away, can't see it will be much different than being connected with a ctek charger, shouldn't harm anything.
Sat Sep 09 2023 2:16am |
*** STAND DOWN! I'M IN!! ***
Tue Sep 12 2023 1:59am |
Tue Sep 12 2023 6:45am |
I haven’t seen that layout col ? Or are they different down under? |
Tue Sep 12 2023 8:14am |
There are some 15a blue fuses near the jack that could be checked. |
Tue Sep 12 2023 8:17am |
There are so many variation of the pin layout down here it is unreal, some don't even show a battery live and pin no. 4 is for the r/h indicator. Cheers Col |
Tue Sep 12 2023 8:45am |
'cos you gotta look at them upside down. Get's people every time. Every home should have one! '06 RRS SC Rimini Red '04 Audi S4 Avant Escort Mk II Sport |
Tue Sep 12 2023 11:37am |
WD40 isn't the best thing to lubricate locks with, it tends to dry out and gums them up, graphite powder is what you really need to use. Cheers Col |
Tue Sep 12 2023 11:46am |
TTR Member Since: 14 May 2023 Location: West Yorkshire Posts: 163 |
Eh up
Tue Sep 12 2023 8:39pm |
Try it with the car locked and then you will know.
Tue Sep 12 2023 9:20pm |
