Home > General > 2018 Alloy Wheels
RonnieB
United Kingdom 2010 Range Rover Sport TDV8 HSE Nara Bronze
2018 Alloy Wheels
Hi, trying to establish if alloys from a 2018 RR Sport would fit a 2010 L320 model, both 20''?
Any advice most appreciated.
Regards
R A Bennett
Post #635563 Mon Sep 04 2023 11:30pm
Yes, just a slightly different offset but not a issue, L320 53mm & L494 49mm if I remember correctly for 20" rims.
Post #635564 Mon Sep 04 2023 11:51pm
RonnieB
Hi Col, thank you for your response and info so no issues using 2018 alloys?
Regards
R A Bennett
Post #635575 Tue Sep 05 2023 6:59pm
NoExpert
Aren’t they 20x8.5 as opposed to 20x9.5? Think 255 is the standard width tire for an 8.5” wide wheel. They will be a little more inset, but not much. Still fit fine. 2011 RRS HSE Luxury 3.0 TDV6 Fuji White on Ebony/Ivory
Post #635577 Tue Sep 05 2023 8:34pm
Might be the 21" that are the 49mm offset and the 20" are 47mm then, still no problem though.
Post #635579 Tue Sep 05 2023 9:50pm
