![]() | Home > General > 2018 Alloy Wheels |
RonnieB Member Since: 23 Feb 2023 Location: Greenock Posts: 4 ![]() ![]() ![]() |
Hi, trying to establish if alloys from a 2018 RR Sport would fit a 2010 L320 model, both 20''?
Col Member Since: 02 Sep 2012 Location: Hawkes Bay NZ Posts: 5063 ![]() ![]() ![]() |
Yes, just a slightly different offset but not a issue, L320 53mm & L494 49mm if I remember correctly for 20" rims.
Hi Col, thank you for your response and info so no issues using 2018 alloys?
Aren’t they 20x8.5 as opposed to 20x9.5? Think 255 is the standard width tire for an 8.5” wide wheel. They will be a little more inset, but not much. Still fit fine. 2011 RRS HSE Luxury 3.0 TDV6 Fuji White on Ebony/Ivory
Might be the 21" that are the 49mm offset and the 20" are 47mm then, still no problem though.
