Home > Technical > Figgy lighter in cup holder section
Kevin-t
Hi folks.
A quickie if I may.
My car says less smokers pack in the build sheet.
However, there is a ciggy lighter socket, albeit with a blank cig lighter in there.
Tried putting a ciggy lighter usb plug in there! No power!
Question is, should there be power? Can I get power to it?
TIA
Kevin Rangerover Sport 2016 4.4 sdv8 A/B loire blue.
Post #635422 Tue Aug 29 2023 8:33pm
TheWojtek
Ignition on? Regards etc.,
Wojtek
WAS: 2006 RRS Supercharged
IS: 2010 RRS TDV8 HSE
Post #635427 Tue Aug 29 2023 10:04pm
Kevin-t
Yes tried with ignition on....Nothing Exclamation Rangerover Sport 2016 4.4 sdv8 A/B loire blue.
Post #635430 Wed Aug 30 2023 6:10am
Pistnbroke
United Kingdom 2009 Range Rover Sport TDV6 HSE Galway Green
Fuse behind the glove box . does the rear and console ones work?
I changed mine for a double USB Always listen to old people or when they die you will live on in ignorance.
The avatar is a picture of the man with a big cock.
Learned to 4x4 on 100 mile beach and Frazer Island QLD
Dont spend money on old cars you will never get it back
Post #635431 Wed Aug 30 2023 6:25am
Kevin-t
Yes
Rear and consul working fine, as is fridge.
May have to check fuse box.Hopefully they are all marked as to which is which!
Post #635433 Wed Aug 30 2023 6:37am
Pistnbroke
Look in the handbook first . You need long nosed pliers to remove Always listen to old people or when they die you will live on in ignorance.
Post #635434 Wed Aug 30 2023 6:38am
Russtyp
It’s fuse 63 in the fuse box behind the glove box 20amp
Changed mine last night if you remove the relay from the right of the fuse it’s a lot easier.
Also if you have small hands as you can’t see anything with your hand in the hole.
Post #635568 Tue Sep 05 2023 7:08am
