![]() | Home > Technical > Figgy lighter in cup holder section |
TheWojtek Member Since: 08 May 2015 Location: Poznań, Poland Posts: 737 ![]() ![]() ![]() |
Ignition on? Regards etc.,
Kevin-t Member Since: 10 Sep 2019 Location: Sheffield Posts: 123 ![]() ![]() |
Yes tried with ignition on....Nothing |
Pistnbroke Member Since: 22 Sep 2020 Location: rugby Posts: 440 ![]() ![]() ![]() |
Fuse behind the glove box . does the rear and console ones work?
Yes
Look in the handbook first . You need long nosed pliers to remove Always listen to old people or when they die you will live on in ignorance.
Russtyp Member Since: 13 May 2022 Location: Caerphilly Posts: 20 ![]() ![]() |
It’s fuse 63 in the fuse box behind the glove box 20amp
