![]() | Home > Faults & Fixes > TDV8 turbo failure (3,6)- which side is common to fail? |
Hightimo Member Since: 08 Jan 2022 Location: Liverpool Posts: 77 ![]() ![]() ![]() |
I have done a couple of these now and given the age and mileage I would replace both , especially if oil has gone into the intercooler, you need to clean everything you can , best you can if that’s the case . Last one I did it had failed and filled the exhaust collector box up with oil , so even after draining there will be smoke for a bit while it all burns off . |
