![]() | Home > Faults & Fixes > Air suspension compressor |
Is it possible you could have a bag leak. Others with more knowledge will be along......... 2006 2.7 TDV6 HSE in Cairns Blue. |
RRSTDV8 Member Since: 13 Aug 2011 Location: Northamptonshire Posts: 9048 ![]() ![]() ![]() |
The bags very rarely fail. More likely is crud from the drier getting and causing valve issues.
Disco_Mikey Member Since: 08 Apr 2012 Location: Dundee, Scotland Posts: 4446 ![]() ![]() ![]() |
Just because the compressor runs, doesn't mean its putting out adequate pressure |
A4j1s0 Member Since: 11 May 2022 Location: Gloucestershire Posts: 29 ![]() ![]() ![]() |
Thank you for your help and replies.
Lrstaylor Member Since: 10 Mar 2022 Location: Kent Posts: 348 ![]() ![]() ![]() |
There is a gap to in the for sale section you can not get better |
Hightimo Member Since: 08 Jan 2022 Location: Liverpool Posts: 77 ![]() ![]() ![]() |
Definitely go for a Bluetooth gap one - save you a fortune and will do everything you need and more .
thank you all for your replies.
So just a quick update.
