Home > Faults & Fixes > Air suspension compressor |
Stevepd Member Since: 22 May 2017 Location: Wiltshire Posts: 1251 |
Is it possible you could have a bag leak. Others with more knowledge will be along......... 2006 2.7 TDV6 HSE in Cairns Blue. |
Mon Aug 21 2023 5:34am |
RRSTDV8 Member Since: 12 Aug 2011 Location: Northamptonshire Posts: 9013 |
The bags very rarely fail. More likely is crud from the drier getting and causing valve issues.
Mon Aug 21 2023 8:18am |
Disco_Mikey Member Since: 08 Apr 2012 Location: Dundee, Scotland Posts: 4420 |
Just because the compressor runs, doesn't mean its putting out adequate pressure |
Mon Aug 21 2023 9:23am |
A4j1s0 Member Since: 11 May 2022 Location: Gloucestershire Posts: 29 |
Thank you for your help and replies.
Thu Aug 24 2023 5:10pm |
Lrstaylor Member Since: 10 Mar 2022 Location: Kent Posts: 348 |
There is a gap to in the for sale section you can not get better |
Thu Aug 24 2023 7:18pm |
Hightimo Member Since: 08 Jan 2022 Location: Liverpool Posts: 77 |
Definitely go for a Bluetooth gap one - save you a fortune and will do everything you need and more .
Thu Aug 31 2023 5:11am |
thank you all for your replies.
Sat Sep 30 2023 3:45pm |
So just a quick update.
Sun Oct 22 2023 3:45pm |
