Home > Maintenance & Modifications > rear ace bar replacement
tess
Do you know how time is involved in replacing the rear ACE anti roll bar on 2012 RRS, I ve bought a new roll bar, how much would the labour be at an indy
Post #634978 Fri Aug 11 2023 1:00pm
Disco_Mikey
4-5 hours, depending how easy it all comes apart
Strongly advise doing the pipes at the same time, save having them done shortly after
Post #634979 Fri Aug 11 2023 1:46pm
tess
Do you mean the front & rear ACE pipes
Post #635008 Sat Aug 12 2023 2:09pm
Disco_Mikey
Rear ARC pipes at the same time as the rear ARC bar Thumbs Up
Post #635010 Sat Aug 12 2023 2:49pm
tess
How much cold climate fluid should I get, does the roll bar come with fluid in it, should I change the ACE block filter as well
Post #635405 Tue Aug 29 2023 11:16am
