![]() | Home > Maintenance & Modifications > rear ace bar replacement |
4-5 hours, depending how easy it all comes apart
tess Member Since: 20 Feb 2020 Location: sheffield Posts: 32 ![]() ![]() ![]() |
Do you mean the front & rear ACE pipes |
Rear ARC pipes at the same time as the rear ARC bar |
How much cold climate fluid should I get, does the roll bar come with fluid in it, should I change the ACE block filter as well |
