Home > General (L494) > Air bag sensor
John11255
Scotland
Air bag sensor
2017 RRS passenger airbag warning light coming on now and again wether someone in seat or not. Any idea why?
Post #634961 Thu Aug 10 2023 7:28am
Scrumpy
It's common on the drivers side because the seat is moved a lot especially with comfort entry enabled (where the seat moves back when you open the door and the forward when you are sitting).
The problem is due to a slight design fault where the airbag loom under the seat is too short so after a while of the seat moving, the connectors work loose.
However, not sure if it would be the same cause on the passenger side, assuming the seat doesn't get moved as much?
A quick fix for me that worked (on the drivers side) was to move the seat all the way forwards, climb in the back and reach under the seat and pull the connectors apart and then firmly push them back.
Once I figured this out, the light never came on again.
Certainly worth a try. 2016 RRS SVR Estoril Blue
Post #634969 Thu Aug 10 2023 8:15pm
Disco_Mikey
Remove the plastic seat cover
Cut away the foam that pushes onto the airbag connector
Or
Replace the connector and wiring with the modified parts
Post #634970 Thu Aug 10 2023 9:07pm
