Home > General > Front sump guard |
Col Member Since: 02 Sep 2012 Location: Hawkes Bay NZ Posts: 5029 |
If you grind or cut the heads off the bolts you will not need to drill out or heat anything up, as the bits will just drop out as there is nothing to hold them in place if the clips have snapped.
Wed Aug 23 2023 9:21am |
I thought you were looking for a replacement guard as the rearmost captive nuts a welded to that.
Wed Aug 23 2023 10:18am |
TTR Member Since: 14 May 2023 Location: West Yorkshire Posts: 165 |
Eh upall
Wed Aug 23 2023 9:06pm |
That is really odd someone must have really bodged it in there somehow, on mine I take the two 6mm headed screws out the of the front plate under the rad area, the two 13 or 14 mm (can't remember which it is) headed ones from the rear of the small guard and it just drops out.
Wed Aug 23 2023 9:46pm |
Eh up Col
Thu Aug 24 2023 6:31am |
Hi,
Thu Aug 24 2023 7:09am |
Andy K Member Since: 18 Sep 2015 Location: GL Posts: 5004 |
Dunno either
Thu Aug 24 2023 7:51am |
H up Andy K
Thu Aug 24 2023 8:36am |
Eh up all
Thu Aug 24 2023 8:31pm |
"Can I please check that once I’ve finished this off, ie repainted and Dinitol it fits as follows:-
Thu Aug 24 2023 8:44pm |
Eh up Col
Thu Aug 24 2023 8:48pm |
Never had a problem with the bolts, just used a bit of copperslip when refitting, however saying that we do have the advantage that they don't salt the roads here in winter so corrosion not a major problem.
Thu Aug 24 2023 8:57pm |
Eh up
Thu Aug 24 2023 9:04pm |
Yeah, had enough of that crap in year's gone bye, but were posh now double garage, heated with carpet on the floor.
Thu Aug 24 2023 9:41pm |
