Home > General > restricted performace issue
r sainsbury
United Kingdom 2012 Range Rover Sport 3.0 TDV6 HSE Adriatic Blue
keeps poping up car drives fine been to land rover they don t knows whats wrong code b0000
inlets done very annoying
Post #634832 Sat Aug 05 2023 9:46am
You need to get the correct codes from them - B0000 doesn't appear to be used as a DTC by Land Rover. Well, I couldn't see it in the workshop manual available online.
When you say "been to Land Rover", do you mean a LR main dealer?
You'd probably be better off going to decent independent LR specialist - the main dealers aren't interested in diagnosing strange errors - too much money to be made from simple servicing of newer cars. 2012 SDV6 - it's missing a couple of cylinders
Post #634842 Sat Aug 05 2023 3:34pm
Tyrefitter
If it’s the 3.0 sdv6 it could be a sticking throttle body flap,I had same a few times then going down the M1 it went into limp mode,LR assist came out & sprayed flap with throttle body cleaner & all was ok,then it went into LR for new throttle body under warranty.
Pic below of clip to remove,pull pipe off & spray flap.
 Andy.
21 Ford Ranger
Gone but not forgotten
Focus RS Red Edition
2015 RRS AB Fuji.
2014 RRS SC Santorini
2016 VW Amarok
2014 RRS AB Fuji
2012 RRS Red Edition Fuji
2015 Nissan Navara
2012 RRS SE Santorini
2008 RRS White
2007 RRS Santorino
Post #634943 Wed Aug 09 2023 11:38am
