Home > General > restricted performace issue |
RRSTDV8 Member Since: 12 Aug 2011 Location: Northamptonshire Posts: 8980 |
You need to get the correct codes from them - B0000 doesn't appear to be used as a DTC by Land Rover. Well, I couldn't see it in the workshop manual available online.
Sat Aug 05 2023 3:34pm |
If it’s the 3.0 sdv6 it could be a sticking throttle body flap,I had same a few times then going down the M1 it went into limp mode,LR assist came out & sprayed flap with throttle body cleaner & all was ok,then it went into LR for new throttle body under warranty.
Wed Aug 09 2023 11:38am |
