![]() | Home > In Car Electronics > Touch Screen Flicking and Static on Audio |
AcePratt Member Since: 23 Oct 2023 Location: Leicester Posts: 16 ![]() ![]() ![]() |
Hi there,
f20gm Member Since: 27 Jul 2023 Location: Leeds Posts: 3 ![]() ![]() ![]() |
Hey
Hi, I can only speak for the head unit. The head unit is grounded via the vehicle harness as it's mounted in a plastic carrier. What I can say is that the MOST FO cable was not that heat resistant (+85DegC) and the temperatures behind the head unit and HLDF were both very hot and had limited space (ventilation truncking etc). It was there that I had the most issues during development. JLR introduced a white cable protector to prevent damage due to bend radius and temperature issues which seemed to work well. However, as usual, these things age so please double check in that area..... |
