Home > In Car Electronics > Satnav maps on facia
jimbg
Frank what model year do you have as there if quite a few differences depending on year. 2023 P440e SE Dynamic on order -cancelled
2022 HSE Dynamic P400e
2006 HSE
Post #634798 Fri Aug 04 2023 3:51pm
5.0 ltr Frank
I have March 2016 SVR.
I even replaced the newer style steering wheel buttons ( Genuine LR not copies ) & correct Ukrainian wiring adapter & that was enough to get alerts from the tracking Centre of possible theft.
I was told "any alteration to the original nav ( besides other things ) will trigger an alert ⚠️ 📢
A lot of people don't subscribe to the incontrol secure & protect service & suspect aftermarket trackers are obviously unaffected.
Post #634800 Fri Aug 04 2023 3:59pm
bmszabo
Netherlands 2013 Range Rover Sport 3.0 TDV6 Autobiography Orkney Grey
I don't know which system You use, I have InControl remote abo (with my 2015 RRS) and it works perfect, with aftermarket headunit replacing oem nav.
Post #634804 Fri Aug 04 2023 5:40pm
5.0 ltr Frank
Just the "incontrol Remote" subscription is not the same. Obviously you can track it ! but you won't get alerts for possible theft if you don't subscribe to it ! & it's this that it doesn't like somehow.
So in conclusion hopefully, the people who adopt the aftermarket nav systems know no different because they don't use the full subscription & only pay for the ability to track it themselves thro' the remote app.
Post #634807 Fri Aug 04 2023 5:56pm
Scrumpy
I replaced the headunit on my 2016 SVR and can confirm that my In Control subscription still worked.
I know this because they called me to see if I was with the vehicle when I was getting on the EuroTunnel at Folkestone last year!
Mind you, not sure what would have happened if I had said "no", probably a bit late!! 2016 RRS SVR Estoril Blue
Post #634808 Fri Aug 04 2023 6:11pm
5.0 ltr Frank
^ What about HUD display ( pressuming you have it )
Post #634809 Fri Aug 04 2023 6:15pm
Scrumpy
Didn't have it, so didn't miss it. All I lost was the sat nav screen in the instrument cluster. 2016 RRS SVR Estoril Blue
Post #634810 Fri Aug 04 2023 6:17pm
5.0 ltr Frank
They 📢 alerted you at the tunnel ( motion detection ) or the signal dropped. Service mode should be selected as you probably know now.
I'm shocked & stunned that you don't receive alerts with aftermarket nav.
Another thing that will trigger an alert is Ghost system immobilizer ( along with a host of other unwanted things ) have you got one of them As well?
Post #634811 Fri Aug 04 2023 6:26pm
jimbg
What alerts are you talking about? I am still in warranty and just get the phone call as mentioned above? 2023 P440e SE Dynamic on order -cancelled
2006 HSE
Post #634812 Fri Aug 04 2023 6:34pm
5.0 ltr Frank
Phone call alerts ⚠️
Post #634813 Fri Aug 04 2023 6:37pm
jimbg
But he did get a phone alert, so I am not sure what you mean? 2023 P440e SE Dynamic on order -cancelled
2006 HSE
Post #634814 Fri Aug 04 2023 6:40pm
5.0 ltr Frank
I'm shocked & stunned that you don't get alerts 'due to the replacement sat nav'.
Post #634815 Fri Aug 04 2023 6:44pm
Scrumpy
To be clear. I had an aftermarket head unit and a Ghost immobiliser as well as a Scorpion Tracker and In Control subscription. I would get the movement alerts on the In Control app and more than once, I would get a call from the In control tracker team, not sure when but I'm guessing it's something to do with geolocation on your phone and the proximity of it to the car. So for example, when I'm on the EuroTunnel, maybe there's no signal on my phone or it's picking up other networks which triggered the call. 2016 RRS SVR Estoril Blue
Post #634816 Fri Aug 04 2023 7:32pm
5.0 ltr Frank
That's what i'm suggesting. Unless you put the incontol into Transport mode ( Ferry / Train / Breakdown ) you'll get notification. However, Your movements alerts of "more than once" now could be a result of the aftermarket nav, & or adding to the mix, the Ghost.
upon "Cold Check" ( when you first put the ignition on & the car does a self check to see if everything's ok ) mine sensed discrepancy in the canbus system which in turn alerted the incontrol of a possible theft, who in turn notified me. so i had to have that removed !
LR told me "Any replacement of the Original Sat Nav system will also do the same"
irrespective of this, Me personally i didn't want to lose the instrument pop up nor my HUD display nor have the incontrol centre on to me all the time, & thought consideration to this must be shown ( Impartially ) to potential "transplanters"
Post #634819 Fri Aug 04 2023 8:33pm
