loonyball
hello all, recently during a very wet spell i discovered both sides of the front floor were not just wet but flooded, i pulled the car (RRS L3200) in my garage, initially i thought windscreen seal, bulkhead leak etc etc, explored everything i could think of but found no obvious signs of water getting in anywhere, decided to remove drivers side wing air vent and at the very bottom between inner and outer wings i discovered a major build up of mud, debris etc, put the hose pipe down there while giving it a good poke to loosen debris and flushed it out, found passenger side was the same, cleaned it out too and now after three weeks and more than plenty of rain the car is bone dry inside once more,
hope this helps with anyone with a similar issue.
Sun Jul 16 2023 2:51pm |
