Home > Tips & Tricks > water ingress fixed !
loonyball
United Kingdom 2007 Range Rover Sport TDV6 HSE Rimini Red
hello all, recently during a very wet spell i discovered both sides of the front floor were not just wet but flooded, i pulled the car (RRS L3200) in my garage, initially i thought windscreen seal, bulkhead leak etc etc, explored everything i could think of but found no obvious signs of water getting in anywhere, decided to remove drivers side wing air vent and at the very bottom between inner and outer wings i discovered a major build up of mud, debris etc, put the hose pipe down there while giving it a good poke to loosen debris and flushed it out, found passenger side was the same, cleaned it out too and now after three weeks and more than plenty of rain the car is bone dry inside once more,
hope this helps with anyone with a similar issue.
Post #634311 Sun Jul 16 2023 3:51pm
Stevepd
That's great and I haven't heard of that one before. Thanks for taking the time to share Thumbs Up 2006 2.7 TDV6 HSE in Cairns Blue.
Post #634329 Mon Jul 17 2023 5:54am
