Home > General > Rear oil leak from where ?
V8steve
England 2008 Range Rover Sport TDV8 HSE Sumatra Black
Hi, does anyone know where the oil leak is coming from. In photo you can see a drop of oil on the bottom of the rear centre bush.
2008 sport v8.
Post #634178 Sun Jul 09 2023 10:34am
Johnrrs
United Kingdom 2013 Range Rover Sport 3.0 TDV6 Autobiography Zambezi Silver
Can’t really see from your photo but on mine (2015 L494) I had an oil leak from the pinion seal which is a common fault on the L494. Could be something similar
Post #634179 Sun Jul 09 2023 11:02am
bmszabo
Netherlands 2013 Range Rover Sport 3.0 TDV6 Autobiography Orkney Grey
Same here. Appears to be a common RRS problem.
Post #634180 Sun Jul 09 2023 11:52am
Could also be a leaking rear anti roll bar. That tends to spread well making it less than obvious where it's coming from. Leaking rear anti roll bars are a reasonably common issue. 2012 SDV6 - it's missing a couple of cylinders
Post #634193 Mon Jul 10 2023 9:24am
