Home > General > Rear oil leak from where ? |
Johnrrs Member Since: 16 Feb 2021 Location: Yorkshire Posts: 460 |
Can’t really see from your photo but on mine (2015 L494) I had an oil leak from the pinion seal which is a common fault on the L494. Could be something similar |
Sun Jul 09 2023 11:02am |
bmszabo Member Since: 10 Aug 2019 Location: Tilburg Posts: 58 |
Same here. Appears to be a common RRS problem. |
Sun Jul 09 2023 11:52am |
RRSTDV8 Member Since: 12 Aug 2011 Location: Northamptonshire Posts: 8982 |
Could also be a leaking rear anti roll bar. That tends to spread well making it less than obvious where it's coming from. Leaking rear anti roll bars are a reasonably common issue. 2012 SDV6 - it's missing a couple of cylinders
Mon Jul 10 2023 9:24am |
