![]() | Home > In Car Electronics > Headunit has gone crazy |
RRSTDV8 Member Since: 13 Aug 2011 Location: Northamptonshire Posts: 9048 ![]() ![]() ![]() |
Do you have anything plugged in to the USB port in the arm rest? I have found that a glitch on a USB stick, for example, can throw up weird errors. Removing the USB sorted the problem.
ifelton76 Member Since: 15 Dec 2020 Location: Merseyside Posts: 24 ![]() ![]() ![]() |
Hi thanks for the reply but I removed that and its still doing it. I have disconnected all the MOST connectors that I can find and they are all blinking red. Is this correct or should it be a steady light? The modules I unplugged where the amplifier, tv tuner and the DAB receiver.
