![]() | Home > General > Suspension Fault - Normal Height Only & W.Yorks Independ |
RRSTDV8 Member Since: 13 Aug 2011 Location: Northamptonshire Posts: 9045 ![]() ![]() ![]() |
It really needs the error codes reading to be sure, but normal height followed by suspension fault is often a symptom of an unhappy compressor / stuck exhaust valve.
Johnrrs Member Since: 16 Feb 2021 Location: Yorkshire Posts: 474 ![]() ![]() ![]() |
I use JAS Landrover specialists to look after my car and I’m not far from you. They are in York and is a 40 min drive for me. |
Stuart Member Since: 18 Oct 2013 Location: Manchester Posts: 581 ![]() ![]() ![]() |
Land Ranger does mine, but they're in Stockport. Not too far from West Yorks if you cant find anyone closer. Get a 2005-2009 RRS (FAH500210) sat nav/dash mat here - the one that wasn't there when you bought the car.
Sheedy773 Member Since: 02 May 2021 Location: Castleford Posts: 27 ![]() ![]() |
I move to a little village on Friday, so it's going to have to wait until then,
Worth the trip over to JAS nr York. Joe Hodgson runs a top outfit Visitor from fullfatrr.com
Compressor dead.
Where did you take it in the end? |
