Home > General > “Reduced Performance” error message…again!
Salisburylander
2011 Range Rover Sport 3.0 TDV6 HSE Bali Blue
This error message happened a year or two back when the MAF on my car decided not to work correctly. I was hoping it may have been something simple and easy to fix again but no, not this time.
A quick trip to the local menders and a split inlet manifold was diagnosed…sigh!
Post #633468 Wed May 31 2023 3:07pm
It is one of "those things that happen", sadly, thanks to the way the manifold is made - two bits of plastic glued together. BTDT. I had both replaced on the basis that if one was going, the other might follow it and the cost in the job is the labour of getting to them. 2012 SDV6 - it's missing a couple of cylinders
Post #633470 Wed May 31 2023 4:41pm
Salisburylander
I had one replaced previously but stupidly, didn’t get them both done at the same time. Hindsight etc…
Post #633471 Wed May 31 2023 5:06pm
Disco_Mikey
Oddly, they don't split along the glued seam. They split just above it, on the radius of the manifold
Post #633473 Wed May 31 2023 5:34pm
That is odd D_M. I guess the mould made it slightly thinner there and it's a weak spot, or it just flexes in use and causes fatigue cracking. 2012 SDV6 - it's missing a couple of cylinders
Post #633479 Wed May 31 2023 7:52pm
According to L/R
Post #633481 Wed May 31 2023 8:39pm
Salisburylander
My car goes in for repair on Monday. The garage has been busy and I’ve had to wait for over 2 weeks. Looks like the parts mentioned in Col’s post have been superseded. If I remember, I’ll try and get a picture of the old manifold.
Post #633790 Sat Jun 17 2023 3:18pm
Disco_Mikey
Must be something in the air (again!)
2 D4's booked in for both manifolds next week, and another set the following week Embarassed
Post #633793 Sat Jun 17 2023 5:40pm
OceanCarl
Spain
FYI, I had a leaking inlet manifold too, however, it was not split or cracked the usual place. Mine had "melted" around injector #8 due to carbon build up from the leaking injector. I.e "the black death" as the MB guys call it..
Post #635535 Sun Sep 03 2023 3:05pm
