Home > General > Aftermarket reversing camera
JonnyCJ
I’m really enjoying my 4.2 SC and SWMBO drives it fairly often.
She does however complain about not having a reversing camera.
Has anyone fitted such a beastie and if so, is it tricky ?
Very happy to strip out front/rear seats, carpet etc - just looking for the best solution to keep her indoors happy.
Post #633378 Fri May 26 2023 7:41pm
Put GVIF in search it will throw up a lot of post as to what various members have done. If you go for the number plate fitted one's it a bit difficult to make a neat job of hiding the wiring due to the design of the split tailgate I believe. On my old pre-facelift I swapped the rear spoiler for facelift one with the camera in it, if you do however use a genuine spoiler you do need to use the facelift hinges as well as the outer mounting are in a slightly different position. I believe there are aftermarket spoiler around fitted with camera which bolt straight on to the pre-facelift.
Will add mine was a HST so used a later A/B spoiler but see no reason why mounting should be any different. The wiring side is quite straight forward. I guess it depends what sort of job you want, and how much you want to spend.
Post #633379 Fri May 26 2023 10:31pm
Lrstaylor
United Kingdom 2006 Range Rover Sport Supercharged Bali Blue
There is a much easier solution.....fit a wolfbox front and rear dash camera or any of the other types you can get now.
I fitted one to our D3, front and rear recording tap the mirror glass and switches from front view to rear view when reversing.
Use it as a rear view all the time because of the poor rear vision from the original mirror. We also have dog cages in the back. No glare at night either from cars behind.
Post #633381 Sat May 27 2023 10:16am
JonnyCJ
Thanks both - will investigate over the weekend
Post #633385 Sat May 27 2023 1:59pm
rayodunne
Canada 2009 Range Rover Sport Supercharged Santorini Black
SWMBO, lmfao 2009 Range Rover Sport Supercharged
Post #633408 Mon May 29 2023 12:49pm
JonnyCJ
I think I might actually have a camera fitted to the spoiler. Is this one ?
If so, what head unit would I need and what should I be looking for in the dash area as a connection ?
Thanks !
Post #633427 Tue May 30 2023 10:45am
that's the window washer fluid
Post #633428 Tue May 30 2023 11:02am
JonnyCJ
Awks ! Laughing
Post #633429 Tue May 30 2023 11:15am
TheWojtek
JonnyCJ wrote:
I think I might actually have a camera fitted to the spoiler. Is this one?
Just don't look into the lens when someone activates rear wipe Rolling with laughter Regards etc.,
Wojtek
WAS: 2006 RRS Supercharged
IS: 2010 RRS TDV8 HSE
Post #633432 Tue May 30 2023 2:47pm
