Home > General > Aftermarket reversing camera |
Col Member Since: 02 Sep 2012 Location: Hawkes Bay NZ Posts: 4986 |
Put GVIF in search it will throw up a lot of post as to what various members have done. If you go for the number plate fitted one's it a bit difficult to make a neat job of hiding the wiring due to the design of the split tailgate I believe. On my old pre-facelift I swapped the rear spoiler for facelift one with the camera in it, if you do however use a genuine spoiler you do need to use the facelift hinges as well as the outer mounting are in a slightly different position. I believe there are aftermarket spoiler around fitted with camera which bolt straight on to the pre-facelift.
Fri May 26 2023 10:31pm |
Lrstaylor Member Since: 10 Mar 2022 Location: Kent Posts: 348 |
There is a much easier solution.....fit a wolfbox front and rear dash camera or any of the other types you can get now.
Sat May 27 2023 10:16am |
JonnyCJ Member Since: 25 Apr 2011 Location: Wirral Posts: 375 |
Thanks both - will investigate over the weekend |
Sat May 27 2023 1:59pm |
rayodunne Member Since: 17 May 2018 Location: Sudbury Posts: 38 |
SWMBO, lmfao 2009 Range Rover Sport Supercharged |
Mon May 29 2023 12:49pm |
I think I might actually have a camera fitted to the spoiler. Is this one ?
Tue May 30 2023 10:45am |
Andy K Member Since: 18 Sep 2015 Location: GL Posts: 4967 |
that's the window washer fluid |
Tue May 30 2023 11:02am |
Awks ! |
Tue May 30 2023 11:15am |
TheWojtek Member Since: 08 May 2015 Location: Poznań, Poland Posts: 737 |
Just don't look into the lens when someone activates rear wipe Regards etc., Wojtek --- WAS: 2006 RRS Supercharged IS: 2010 RRS TDV8 HSE |
Tue May 30 2023 2:47pm |
