![]() | Home > Technical > Epb unit |
RRSTDV8 Member Since: 13 Aug 2011 Location: Northamptonshire Posts: 9049 ![]() ![]() ![]() |
The problem is that the EPB module (which controls the EPB system) is connected to the switch and also to the CANBUS. So you can get cascade failures caused by something else throwing a fit.
jk3528 Member Since: 30 May 2021 Location: stoke on trent Posts: 75 ![]() ![]() |
If I could sort out which wires in the switch are connected when not operating I might be able to bypass it and see if that stops the fault from showing up |
Andy K Member Since: 18 Sep 2015 Location: GL Posts: 5036 ![]() ![]() ![]() |
You may as well clean the inside of the epb switch (it’s like a tv remote control) or get a second hand one |
Assuming you have an L320, the workshop manual is here: https://www.mediafire.com/file/yunzrqm47py4pww/RRSL320WSM2006.pdf There is a section on the EPB and the wiring layout is shown in the wiring diagram section. Good luck. ![]() 2008 TDV8 - it was a labour of love and is much missed |
Yes it’s a 2006 l320 2.7v6
Pufftmw Member Since: 23 May 2012 Location: Carmarthenshire Posts: 1053 ![]() ![]() ![]() |
The other thing that could be initiating the traction control is a sticky front left calliper (seeing as its a roundabout). Happened to me, took me a while to work it out. |
