Home > General (L461) > Timed charging on P440e |
B McP Member Since: 01 Sep 2023 Location: Aberdeenshire Posts: 21 |
I have a 2024 model P460E and am a Octupus customer on the EV rate system which is between midnight and 06:00hrs. I programme the charge via the Octopus AP not the car or the charger and it works every time. I set the amount of charge I want and the Octopus AP does the rest. |
Mon Oct 14 2024 7:59pm |
jimbg Member Since: 29 Jan 2013 Location: By the River Dart Posts: 1817 |
What charger do you have?
Mon Oct 14 2024 9:28pm |
terrygill Member Since: 25 Jul 2006 Location: East Yorkshire Posts: 14 |
Our is a 2024 460e too. We are also with Octopus and on the low rate, which in our area is 00:30 - 05:30hrs.
Mon Oct 14 2024 10:51pm |
You can still have an off peak tariff but you will just need to use the car to schedule it.
Tue Oct 15 2024 8:20am |
I have a MyEnergi Zappi and during the setup with Octopus through the AP I was able to choose this device and the model of car I have. |
Tue Oct 15 2024 8:35am |
Yes, now it's the EV charger controlling it, when I signed up 3 years ago the Sport was recognised and worked fine. Did you not get the email from Octopus informing you the Sport was off the list? 2023 P440e SE Dynamic on order -cancelled
Tue Oct 15 2024 9:41am |
I switched to Octupus approx 3 months ago and set my car and charger up in the Octopus AP then. The Octopus AP is the only control mechanism I use to charge the car. As soon as I plug the car in, I get a message through the Octopus AP that outlines the charge times and they are within the EV low cost window. |
Tue Oct 15 2024 10:23am |
Okay, you joined just as they dropped JLR support, but you have one of the 4 supported chargers so are good to go. 2023 P440e SE Dynamic on order -cancelled
Tue Oct 15 2024 11:31am |
