![]() | Home > Technical > RRS SDV6 3.0 Starts and Dies |
Googs Member Since: 04 Oct 2022 Location: Greens Beach Tasmania Posts: 89 ![]() ![]() ![]() |
If you want to remove the fuel pump (fuel) you have to drop the tank there is no access under the seat.
nike_bytom Member Since: 06 Apr 2023 Location: Kettering Posts: 7 ![]() ![]() ![]() |
Thank you for replay, already replaced low pressure fuel pump last weekend still no luck... starts and dies.
Hi All
After replacing HPFP still no luck, can not start engine.
TheWojtek Member Since: 08 May 2015 Location: Poznań, Poland Posts: 737 ![]() ![]() ![]() |
My BMW used to do exactly that when the camshaft position sensor was faulty. No codes either. Regards etc.,
Thanks Wojtek, I think I will start first by replacing crankshaft sensor (it looks like common problem on those engines to fail with no code?) and if that not help I will go for camshaft sensor replacement.
Cheers, powodzenia! Regards etc.,
RR-Panda Member Since: 01 Aug 2023 Location: Gold Coast Posts: 6 ![]() ![]() ![]() |
Hi nike_bytom, Did you get this resolved? I have the same issue and have done much of what you mentioned to no avail, Cheers, Neil |
MickEng26 Member Since: 19 Jan 2025 Location: Sunderland Posts: 1 ![]() ![]() ![]() |
Did ypu get to the bottom.of this ??? |
Unfortunately I did not get this solved and sold the car 🥺 Regards Raf |
