Home > Technical > RRS SDV6 3.0 Starts and Dies |
Googs Member Since: 04 Oct 2022 Location: Greens Beach Tasmania Posts: 89 |
If you want to remove the fuel pump (fuel) you have to drop the tank there is no access under the seat.
Sat Apr 29 2023 7:21pm |
nike_bytom Member Since: 06 Apr 2023 Location: Kettering Posts: 6 |
Thank you for replay, already replaced low pressure fuel pump last weekend still no luck... starts and dies.
Sat Apr 29 2023 8:04pm |
Hi All
Tue May 02 2023 5:08pm |
After replacing HPFP still no luck, can not start engine.
Wed May 24 2023 6:56pm |
TheWojtek Member Since: 08 May 2015 Location: Poznań, Poland Posts: 737 |
My BMW used to do exactly that when the camshaft position sensor was faulty. No codes either. Regards etc.,
Wed May 24 2023 7:51pm |
Thanks Wojtek, I think I will start first by replacing crankshaft sensor (it looks like common problem on those engines to fail with no code?) and if that not help I will go for camshaft sensor replacement.
Thu May 25 2023 11:15am |
Cheers, powodzenia! Regards etc.,
Thu May 25 2023 5:54pm |
RR-Panda Member Since: 01 Aug 2023 Location: Gold Coast Posts: 6 |
Hi nike_bytom, Did you get this resolved? I have the same issue and have done much of what you mentioned to no avail, Cheers, Neil |
Thu Aug 03 2023 12:52am |
