![]() | Home > Technical > Both my key fobs have died and I'm locked out of the car.... |
SuperC Member Since: 24 Feb 2016 Location: Midhurst, West Sussex Posts: 75 ![]() ![]() ![]() |
Hi All,
Col Member Since: 02 Sep 2012 Location: Hawkes Bay NZ Posts: 5044 ![]() ![]() ![]() |
You can get into the car by flipping off the plastic cover on the n/s door handle and unlock using the key blade. Place the remote under the steering column and try to start as normal, there is a location area in the consol to place the key, If I remember right the fob buttons have to face down.
Thanks. Giving it a go. I'll let you know how it goes...... Cheers,
I'm in. It may not have been the fob. The car is completely dead. Just had a new battery a couple of weeks ago but, this is not like it gone flat. This is completely dead...... B*llocks! Cheers,
RRSTDV8 Member Since: 12 Aug 2011 Location: Northamptonshire Posts: 9026 ![]() ![]() ![]() |
This can be caused by the keyless entry system - I had this a few months ago out of the blue. I even changed the key fob battery (I had a spare in the car). No use. Did some online research and found out about the keyless entry system.
appreciate the input. Unfortunately, not this time: the battery is completely drained. Its less than 6 weeks old so I assume something has drained it. Back up and running with the car now in the shop. There's a list of error codes as long as your arm so, can't see the wood for the trees at the moment.
Hopefully they can sort it. You might be interested in this thread: https://www.disco3.co.uk/forum/topic167874.html 2012 SDV6 - it's missing a couple of cylinders
Scrumpy Member Since: 11 Nov 2016 Location: Surrey Posts: 567 ![]() ![]() |
Would that be Jack Russells? I use Glenrands and can highly revcommend them. Hopefully they'll get it sorted for you. 2016 RRS SVR Estoril Blue 2005 4.2L Supercharged Java Black - gone but was my first love. -------------------------------------------------------------------------------------------------------- If we all point our RR's in the same direction and accelerate at the same time can we turn back time? |
Yes indeed, 3 of them. Must have smelt my old Labrador on me and the biscuits normally in my pocket. Lovely dogs.
