Home > Technical > Both my key fobs have died and I'm locked out of the car.... |
SuperC Member Since: 24 Feb 2016 Location: Midhurst, West Sussex Posts: 75 |
Hi All,
Thu Apr 13 2023 10:55am |
Col Member Since: 02 Sep 2012 Location: Hawkes Bay NZ Posts: 4969 |
You can get into the car by flipping off the plastic cover on the n/s door handle and unlock using the key blade. Place the remote under the steering column and try to start as normal, there is a location area in the consol to place the key, If I remember right the fob buttons have to face down.
Thu Apr 13 2023 11:13am |
Thanks. Giving it a go. I'll let you know how it goes...... Cheers,
Thu Apr 13 2023 11:42am |
I'm in. It may not have been the fob. The car is completely dead. Just had a new battery a couple of weeks ago but, this is not like it gone flat. This is completely dead...... B*llocks! Cheers,
Thu Apr 13 2023 11:58am |
RRSTDV8 Member Since: 12 Aug 2011 Location: Northamptonshire Posts: 8971 |
This can be caused by the keyless entry system - I had this a few months ago out of the blue. I even changed the key fob battery (I had a spare in the car). No use. Did some online research and found out about the keyless entry system.
Thu Apr 13 2023 2:08pm |
appreciate the input. Unfortunately, not this time: the battery is completely drained. Its less than 6 weeks old so I assume something has drained it. Back up and running with the car now in the shop. There's a list of error codes as long as your arm so, can't see the wood for the trees at the moment.
Thu Apr 13 2023 4:06pm |
Hopefully they can sort it. You might be interested in this thread: https://www.disco3.co.uk/forum/topic167874.html 2012 SDV6 - it's missing a couple of cylinders
Thu Apr 13 2023 7:24pm |
Scrumpy Member Since: 11 Nov 2016 Location: Surrey Posts: 567 |
Would that be Jack Russells? I use Glenrands and can highly revcommend them. Hopefully they'll get it sorted for you. 2016 RRS SVR Estoril Blue 2005 4.2L Supercharged Java Black - gone but was my first love. -------------------------------------------------------------------------------------------------------- If we all point our RR's in the same direction and accelerate at the same time can we turn back time? |
Fri Apr 14 2023 5:56pm |
Yes indeed, 3 of them. Must have smelt my old Labrador on me and the biscuits normally in my pocket. Lovely dogs.
Sat Apr 15 2023 1:39pm |
