![]() | Home > Technical > ZF8 Transmission Problem Help Please |
Dave-t Member Since: 18 Jan 2020 Location: Glasgow Posts: 436 ![]() ![]() |
What's the age and mileage?
5.0 ltr Frank Member Since: 28 Mar 2023 Location: Birmingham Posts: 37 ![]() ![]() |
it's 2016 and 60500. i had it done as preventative measure.
As it's only when cold it could be the cars way of warming the oil to temperature. Also these things are discussion worthy about getting off the line. If it were me I would think much about it, especially as you've done a oil change. If it was juddering etc I'd be giving it more thought. Others will respond shortly though. 2006 2.7 TDV6 HSE in Cairns Blue. |
^ Thank you |
djpgowrie Member Since: 04 Jun 2020 Location: Manchester Posts: 43 ![]() ![]() ![]() |
FWIW i agree with this - my 6 speed box holds all gears a little longer when cold. its almost as if it wants higher revs to get to operating temp quicker |
^ Thank You |
TheWojtek Member Since: 08 May 2015 Location: PoznaĆ, Poland Posts: 737 ![]() ![]() ![]() |
Same here, when cold, my 6HP holds the gears up to 2000 rpm. It was like this before megaflush, it's the same after megaflush. Regards etc.,
^ Thank You |
RRSTDV8 Member Since: 12 Aug 2011 Location: Northamptonshire Posts: 9026 ![]() ![]() ![]() |
It is designed to do this, as you say, in order to help speed up the warming process - to help emissions more than anything else. 2012 SDV6 - it's missing a couple of cylinders 2008 TDV8 - it was a labour of love and is much missed |
