Home > Technical > ZF8 Transmission Problem Help Please |
Dave-t Member Since: 18 Jan 2020 Location: Glasgow Posts: 436 |
What's the age and mileage?
Tue Mar 28 2023 11:14am |
5.0 ltr Frank Member Since: 28 Mar 2023 Location: Birmingham Posts: 37 |
it's 2016 and 60500. i had it done as preventative measure.
Tue Mar 28 2023 11:28am |
Stevepd Member Since: 22 May 2017 Location: Wiltshire Posts: 1251 |
As it's only when cold it could be the cars way of warming the oil to temperature. Also these things are discussion worthy about getting off the line. If it were me I would think much about it, especially as you've done a oil change. If it was juddering etc I'd be giving it more thought. Others will respond shortly though. 2006 2.7 TDV6 HSE in Cairns Blue. |
Tue Mar 28 2023 12:23pm |
^ Thank you it is only when it's cold. |
Tue Mar 28 2023 12:30pm |
djpgowrie Member Since: 04 Jun 2020 Location: Manchester Posts: 43 |
FWIW i agree with this - my 6 speed box holds all gears a little longer when cold. its almost as if it wants higher revs to get to operating temp quicker |
Tue Mar 28 2023 1:25pm |
^ Thank You |
Tue Mar 28 2023 1:32pm |
TheWojtek Member Since: 08 May 2015 Location: PoznaĆ, Poland Posts: 737 |
Same here, when cold, my 6HP holds the gears up to 2000 rpm. It was like this before megaflush, it's the same after megaflush. Regards etc.,
^ Thank You |
Tue Mar 28 2023 1:38pm |
RRSTDV8 Member Since: 12 Aug 2011 Location: Northamptonshire Posts: 8983 |
It is designed to do this, as you say, in order to help speed up the warming process - to help emissions more than anything else. 2012 SDV6 - it's missing a couple of cylinders 2008 TDV8 - it was a labour of love and is much missed |
Tue Mar 28 2023 2:31pm |
Tue Mar 28 2023 2:41pm |
