Home > Technical > Another tdv8 to come back from the brink !
Hightimo
Start of another tdv8 non runner - needs turbos …… and probably a whole load of other stuff ! It does seem to have sank down on the rear suspension while it’s been ‘waiting’ for the job- any ideas /common causes ?
Post #631629 Tue Mar 14 2023 8:09pm
JonnyCJ
Rear suspension sag sounds like a rebuild on the rear valve block, if it’s both sides. £15 or so for a new set of seals from eBay and watch Hazy’s videos on YouTube on how to do it.
Not rocket science !
Post #631787 Sun Mar 19 2023 8:44pm
Hightimo
Finally got round to sorting the turbos! Two inserts and a full service later and it’s all running well - after I drained all the oil out of the exhaust and recovered the missing impeller wheel from the ns turbo ! - did smoke a little after start up !
Post #633532 Fri Jun 02 2023 9:49pm
Hightimo
Update - suspension was all ok - looks like it just had a moment as the battery was off for a while - just the rear brake to sort now and handbrake module!
Post #633533 Fri Jun 02 2023 9:51pm
JonnyCJ
Ian Barclay in Birkenhead know these cars inside out. All they do is LR, so if you get stuck give them a call.
Post #633536 Sat Jun 03 2023 9:00am
