![]() | Home > Technical > Another tdv8 to come back from the brink ! |
JonnyCJ Member Since: 25 Apr 2011 Location: Wirral Posts: 428 ![]() ![]() |
Rear suspension sag sounds like a rebuild on the rear valve block, if it’s both sides. £15 or so for a new set of seals from eBay and watch Hazy’s videos on YouTube on how to do it.
Hightimo Member Since: 08 Jan 2022 Location: Liverpool Posts: 77 ![]() ![]() ![]() |
Finally got round to sorting the turbos! Two inserts and a full service later and it’s all running well - after I drained all the oil out of the exhaust and recovered the missing impeller wheel from the ns turbo ! - did smoke a little after start up !
Update - suspension was all ok - looks like it just had a moment as the battery was off for a while - just the rear brake to sort now and handbrake module! |
Ian Barclay in Birkenhead know these cars inside out. All they do is LR, so if you get stuck give them a call. |
